Results 1 to 10 of 16
Thread: what size wheels???? calling all you fitment experts
    Senior Member DRFTR86's Avatar
    Richard
    South Oakleigh
    Default what size wheels???? calling all you fitment experts
    hey all, so im putting a bw78 r31 diff into my 86, i havent got it shortened, so it is 60 mm wider.
    my rear flares are rusty as hell and i know i wont be able to fit my 15 X 8 -4 superlights on with the new diff and with the current guards.
    so im leaning towards some bolt on guards, i have sourced a supplier which can provide me with either 25mm, 50mm, or a staggering 100mm.
    just want some feedback as to what size rim and tyre combo to suit either the 50mm or 100mm flares, looking predominantly at superlights and challengers.
    any feed back would be appreciated
    BTW engine is a ca18det which has made 206.4 rwkw, i dont think 195s will suffice to the grip i am gonna need
    PROTEK TYRE AND AUTO
    SQ ENGINEERING
    NCCE
    Veteran Robo86's Avatar
    Rob
    origin bolt on rear flares are big enough to accomidate a 8.5j -22 with 195 (using standard T diff) so 8j -34 (adds 30mm from each side of the diff) is only 6mm more poke (each side) than my 8.5 -22 and the origins had a good 10mm left in them.
    footnote:
    -15x8-4 (effective -34 due to diff) should fit with origin rear bolt on flares, providing tyres arnt wider then 195/
    http://shirtstuckedin.com/
    my corolla
    Bosman Wholesale Tyres
    3274 5374 - Roy
    Veteran Konakid's Avatar
    Henry
    Eastern
    Dont use an r31 diff
    Use an F or G series.
    Nathan
    Lilydale
    R31 diff is fine, just get the right wheels. maybe sell the superlights and get better offset ones to suit ure setup.
    -nath
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    yeah sell em cheap cheap 2 me ^.^ atm i only got pesos that okay ?
    Richard
    South Oakleigh
    atm ive got my 15 X 7 0 offset meshies on, superlights on my front to clear the fc caliper setup, but me being me, i want it low, phat, just want it to look damn ridicoulous, how big are the origins robo???
    now sort of leaning towards jsut the 25mm and runs 7s all the time, mite buy a set of rewinds if it comes down to it, or even 8 with 0 offset, sportmaxx 512s
    and dave ull need plenty of pesos
    SQ ENGINEERING
    NCCE
    Dave
    Western Suburbs
    pretty sure origins are 25 too ?
    Rob
    yer 35mm i think
    my corolla
    3274 5374 - Roy
    Senior Member s14seriesII's Avatar
    Mark
    Southern
    origin rear flares are 40mm wider than stadard so the superlites would fit perfect with your diff and 195 tyres ive had the 15*8 neg 9challengers with 30mm bolt on spacers on the back of mine
    Owner built and tuned 9000rpm 402kw atw 3sGTE - AE86
    Quote Originally Posted by Beau View Post
    4ages are for the scared
    Richard
    South Oakleigh
    still leaning toward to 25mm atm, and run a 8 0 offset with a 195, or as S14seriesII said, hes running a 40mm flare and has had challengers on the back with a 30 mm bolt on and it still clears, how about a 50mm flare with challengers and 205 50 15??, that should work out shouldnt it??
    SQ ENGINEERING
    NCCE
  1. Calling fibreglass experts;
    By AE82stew in forum Technical - Questions
    Last Post: 8th February 2011, 06:48 PM
  2. Replies: 9
    Last Post: 23rd June 2010, 11:54 PM
  3. Wtb:wheels any size must be in sa
    By thekid in forum Cars or Parts Wanted
    Last Post: 27th May 2009, 11:03 AM
  4. turbo experts 4agte
    Last Post: 13th March 2009, 05:53 PM
