Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: 4age in ADM 86 won't start. Wiring?
  1. #11
    Dec 2012
    Cheers again for the reply. The injectors have dark red / orange connectors on them.
  2. #12
    Dec 2012
    double post
  3. #13
    Its been about 2 years since i last did a bigport conversion... Disconnect the ecu, apply voltage to each injector for half a second to manually pulse them and try starting...
    That'll confirm it 100% if it is injector pulse related.
    You definately have a strong spark? Timing verfied (timing belt as well) ?
  4. #14
    Dec 2012
    Thanks for the replies again everyone, can't seem to find the connector nor resistor box, however this doesn't mean it wasn't left in the donor car. The impedance of the injectors is 2.4 Ohms and they have a dark red / orangey connector on them. Are this the type that require the resistor network box?
    Cheers again in advance.
    -Sam
  5. #15
    Veteran slide86's Avatar
    Huw
    Hills
    If you spray start ya bastard or carry cleaner down the throttle and then crank it, does it fire into life for a few seconds?
  6. #16
    Dec 2012
    hey silde86, we havent tried that but after thoroughly going all the correct readings and continuity with a multi-meter, it all seemed legit - still no injectors actuating. We removed the fuel rail and injectors and i tested them one by one using a brief pulse of 12V, 3 out of the 4 are functional. All injectors measure 2.4 ohms however could this one faulty injector stop them all from firing?
    Cheers again for the replies.
  7. #17
    It'll run on 3 cycl , just poorly. Not sure of the impact electrically but leave it disconnected and try anyway.
    Might be worth trying another ecu?
  8. #18
    Dec 2012
    That was my suspicion Matt. I hope the ECU / Map sensor / dizzy sensor isn't fucked
  1. 4age won't start
    By Brokenships in forum Technical - Questions
    Last Post: 1st June 2012, 11:10 PM
  2. 16v 4AGE dies warm then won't start again
    Last Post: 3rd May 2012, 10:06 AM
  3. E7 4AGE Won't Idle, Not Hunting Or Cold Start
    By KurtHS in forum Technical - Questions
    Last Post: 3rd November 2011, 06:26 PM
  4. 4AGE 20v Help! - won't start!
    By DAMO46 in forum Technical - Questions
    Last Post: 5th March 2010, 06:53 PM
  5. wiring up 4age into adm 86
    By driftnick13 in forum Technical - Questions
    Last Post: 2nd January 2010, 05:00 PM
