1 x 4AGE big port head with standard cams and valves assembled - used condition - bolt it on to get you out of trouble or strip and use for your build $150
1 x 4AGE small port head with standard cams and valves assembled - used condition - bolt on to get you out of trouble or strip and use for your build $150
1 x 4AGE 7 rib block standard bore, (non oil squirter and no crankshaft) bare with main caps - used condition needs hone or machine to suit your new pistons $100
4 x 4AGE small port standard size pistons only (no rods) - used condition $50
4 x 4AGZE low comp standard size pistons only (no rods) - used condition $50
All items can be shipped at buyers expense - I prefer e-go couriers as there is a depot nearby or you arrange your own.
I can send pics to your phone if you PM your mobile number.
Otherwise pick up is prefered due to weight from Taren Point in southern Sydney
Total price negotiable if you buy the lot. Sorry, I will not sell cams separately
