Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: 4age 20v not running
  1. #11
    Sep 2012
    Tristan
    Koongal
    so i've Finally found whats wrong with my 20v...FINALLY
    2 things
    1. bad tuner is bad and did not have a clue what he was doing! ignition chart was too much all over the shop and engine running way to rich so, fouled plugs very quickly
    2. faulty x4 module! even though i had sent it to microtech for testing and both the lt10s and x4 module 'was fine' i found this out by the people who are now tuning it for me, and i'm getting another x4 on the way
    however my tuner has suggested because of where i live i should wire in a air temp sensor on the microtech, does anyone know if a 4afe air temp sensor will be fine?? it should have the right specs i would imagine
  2. #12
    Mar 2011
    Ali
    Those X4 / X6 boxes are shit house!
    I thought that may have been some part of the blame, that why I brought up what I did in other post.
    You should be able to use that 4AFE air temp sensor.
    I had 13B Mazda ones laying around that I used on 1UZ, worked fine, so I don't see why not.
  3. #13
    Sep 2012
    Tristan
    Koongal
    For sure!
    who in there right mind would buy microtech :/
    and sweet i shall wire it in tomorrow and get it tuned the following day! then maybe happy days
  4. #14
    Senior Member cooter's Avatar
    Sep 2010
    Craig
    Perth hills
    i dont see the microtech as too bad. ive had an lt10s on my blacktop since 06 n its been great. never given me a hassle. sure it doesnt have the bells n whistles of the higher end ecus but its ok
    glad you got it sorted but
  5. #15
    Sep 2012
    Tristan
    Koongal
    some people have happy stories with there microtechs i guess
    i've yet found MORE problems starting to think is it worth have a 20v?
    so i found that my cas trigger somehow had to much of a distance between the trigger wheel and the pick up point i closed in the pic up and it started running better
    then to my finding aswell i found cylinder 2 exhaust valves are stuck fully open and seized / rusted in place
  6. #16
    Mar 2011
    Ali
    Sounds like the motor is half the trouble.
    You sure they seized, tried valve saver on them?
  7. #17
    Sep 2012
    Tristan
    Koongal
    yeah it is futo, i am almost tempted to buy another 20v engine.. not as yet i have to make up some long nose pliers with little plates to sit in the collet position so i can actually grab the valves and free them up.. i actually broke a spring retainer in the process of tapping the valves ( i was hoping it would just spring back up) but it snapped in two, so i'm getting 2 sets of new spring retainers genuine in aus delievered to me ...i have been soaking the valves in rost off though.
    although the whole valves sticking open isn't that uncommon but it happens to engines that sit around alot - like mine did :/ alot of the old falcons did the same if parked in car lots for a long time
  8. #18
    Mar 2011
    Ali
    Yup, and you get that valve saver stuff and poor it on them, crank it over and try fire it up, takes a fair few goes but usually does the trick.
    But seems like your past there.
  1. Replies: 4
    Last Post: 26th February 2012, 09:25 PM
  2. WTB: Complete 4age rwd running.16v or 20v
    By phat rolla in forum Cars or Parts Wanted
    Last Post: 31st January 2012, 11:10 PM
  3. suitable gearbox/diff upgrades for ADM sprinter running 4AGE 20V???
    By schmykel in forum Technical - Questions
    Last Post: 20th July 2010, 11:40 PM
  4. running into problems with 20v installation
    By sprinters_r_mad in forum Technical - Questions
    Last Post: 11th December 2007, 10:26 PM
  5. Running coils on a 20v
    By DRF786 in forum Technical - Questions
    Last Post: 11th October 2006, 07:24 PM
