Results 1 to 10 of 14
Thread: AE86 4age 16v wiring problem????
    Mar 2011
    Ali
    Doesn't Wide body Camry have the 3/5SFE, like the next model up SXV10.
    Hmm, Actually you might be right.
    Its the 4cyl version of the Camry pictured above that I got the body harness plug from that fit Bigport ECU perfect.
    I just took ecu in with me, showed it to the guy, and went hunting through all Toyota's till found one of those magnificent POS pictured above.
    It didn't actually have a motor in it, I just assumed it was a 4A variant as the plug went straight in to my 4A ECU.
  1. (KE70: 4K-C --> 4AGE 16V Big Port) 12v Engine Power Wiring Q
    By bally in forum Technical - Questions
    Last Post: 16th February 2011, 04:37 PM
  2. sr wiring problem
    By eikots in forum Technical - Questions
    Last Post: 27th August 2010, 08:36 PM
  3. 4age wiring problem!
    By 15LIDE in forum Technical - Questions
    Last Post: 23rd August 2010, 12:02 PM
  4. 4age wiring problem!
    By sic86 in forum Adelaide & SA Events and Discussion
    Last Post: 17th April 2010, 10:08 AM
  5. SR Wiring Problem
    By bigm in forum Technical - Questions
    Last Post: 11th January 2010, 01:49 PM
