I've just finished replacing my rotors. and put on the bit that holds in the pads (has 2 bolts). but the cylinder won't even fit over the disc now.
the part with the two teeth that holds the outer pads in hits the rim of the disc now. how do I adjust it so there is room for the outer brake pads?
