Results 11 to 20 of 21
Thread: solid lifter upgrade 16v 4age.
    Mt Macedon
    I was initially going to say "why not do it the easy way and just get 1SZ bits", but then I remembered all the ridiculous stuff I've done that made sense at the time... though maybe not quite so much now.
    So respect for doing it the other way. It may be a bunch of work, but I hope you get it worked out and running well.
    Senior Member MoNsTaR's Avatar
    Jul 2009
    Richmond
    and a comparison shot
    Quote Originally Posted by sam2306 View Post
    its not a gang till we have stickers
    Quote Originally Posted by *E7* View Post
    rust is lighter than carbon fibre
    Jul 2009
    Richmond
    Ok, heres the verdict, IT WORKED!!!!!!!!!!!
    Works a charm really......when you dont fuck up haha
    i ended up typing 31.25 into the machine instead of 31.025, so new head it is but for proof of concept it worked.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    That's really neat, you have done well. How is the weight of the shimless compared to the original 4a bucket and shim together?
    Jul 2009
    Richmond
    ok, head is finnished ill get some pics up asap. they worked GREAT!!! with a 304 duration 11mm lift cam, they didnt need any clearancing other then 2 spots.
    May 2012
    ACT
    belconnen
    This is a clever mod for when insane cam lift is needed.
    Does anyone think something like this could work on the 20v head?
    If they're 23mm stock, would boring them out to fit the 1sz 28mm buckets be too much? (or something a bit smaller, if it can be found.)
    Endeavour Hills
    there is very little meat between the intake buckets on a 20v
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    There is no point going to bigger buckets on a 20v, the spark plug tubes need clearancing with big cams as is, any bigger and you would need to start moving the spark plug and exhaust ports.
    Senior Member Prime86's Avatar
    Sep 2009
    Brad
    Perth hills
    This is an interesting thread and idea to modify the lifter bores to suit the 1zzfe tappets. I have a modified small port head that was fitted with the shimless 1szfe conversion with big cams. I noticed the 1szfe lifters are higher than the standard 4age ones, I've since removed them for a shim under conversion and there just sitting around in the shed. Can I ask what the rev limit of the engine will be when up and running?
    May 2010
    bui
    Hi there,
    Any chance to measure up how much higher is the 1SZ-FE lifter compare to stock 4AGE shim over bucket? I'm about to do the solid lifter conversion and was worrying that the 1SZ-FE will bottom out in the lifter bore with the high lift cams.
  1. Replies: 2
    Last Post: 7th October 2011, 11:28 PM
  2. 4AGE 16V injector upgrade
    By aus_86 in forum Technical - Questions
    Last Post: 5th April 2011, 12:14 AM
  3. 4age solid engine mounts
    By timpy in forum Car Parts For Sale
    Last Post: 31st March 2011, 06:09 PM
  4. 4age rwd solid mounts, twin tip exhaust, sydney
    Last Post: 28th November 2010, 04:07 PM
  5. 4AGE lifter size
    By driftnick13 in forum Technical - Questions
    Last Post: 20th September 2009, 10:23 PM
