Results 1 to 10 of 20
Thread: Circuit Open Relay(COR) Part number 85910-12080 question
    Mar 2011
    Ali
    Sorry, read Edit
    Never done MAF/COR before.
    LS400 used funky fuel pump controller set up, massive (and expensive) heat sink looking gizmo which I don't fully understand or have, so went for COR.
    Just asking the question as the last bit got me jumping.
    But in saying that, If I stay clear of FC pin on this ECU (half speed pump) and use FPR to trigger COR it should work?
    The write up states FPR won't trigger "normal" relay, hence why I was looking at MAF directly.
    Is COR lower voltage the "normal" relay?
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Don't try to trigger a fuel pump off the AFM, its not designed for it and you'll stuff it.
  1. Fuel Opening Circuit Relay
    By Matt in forum Technical - Articles
    Last Post: 12th March 2017, 07:50 PM
  2. Replies: 1
    Last Post: 16th September 2012, 11:49 AM
  3. Obtaining a circuit opening relay
    By paulv in forum Technical - Questions
    Last Post: 27th March 2012, 08:34 PM
  4. Replies: 0
    Last Post: 12th September 2008, 06:01 PM
  5. Replies: 3
    Last Post: 17th April 2008, 12:37 PM
