same mounting points, so you need 4ac or rwd 4age. I have some if you need them
Just a really quick question.
Are 20v and 16v engine brackets the same as each other?
Obviously the 20v is FWD only, but does the block take the same mounting holes, and would these mount up the same as a 16v to the crossmember?
I have a smallport 4age going into my sprinter, and have engine mounts, but no brackets. I'm just trying to open the options, as someone I know has some 20v ones.
Or should I really only be looking for RWD 4ac and 4age brackets?
Thanks in advance.
Okay, thanks!
I've shot an sms to a couple mates that may have some around.
How much were you chasing for them?
I'm able to pick them up, you're not too far away![]()
$120 for the metal brackets only
