Some of us are not being negative, just merly giving some advice, it needs to be clarified that advice is simply that, its not the same as drawing a line on the ground and saying walk exactly on that line, its more saying your target is "over there" you might want to think about staying between the 2 trees.
there were some "bait words" in the 1st post that are no longer there, which i think triggered the responses along with the specified use of the car..
The thing i really dig, is the Japs that yank the Rb motor out of a skyline and replace is with an SR.
by all means im in no way telling you what to do, if you have any questions im more then willing to help you, but with this conversion, and its intended purpose, you will need to do a bit more thinking about everything you do.
and in the end of the day, if your going to compete in anything, power is nothing compared to weight reduction.
good luck,
sign up to
upload your pics and simply post the IMG tag into the thread and your pictures will magically appear
