Page 4 of 4 FirstFirst 1 2 3 4
Results 31 to 35 of 35
Thread: Rust Removal Tips n Tricks
  1. #31
    Veteran haveaparty's Avatar
    Mar 2010
    Brett
    Crestmead
    heres some rust repairs ive done on my ae86 over the last couple days. I managed to fins rust free second hand panels to help with my repairs.
    some one has repaired this car before but dodgey af
    cut out the area I wanted to replace
    then used the cuts I had to make the replacement section
    cleaned everything up and weld it in
    did the same for the quarter window section
  2. #32
    Nov 2015
    Michael
    Werribee
    Just a browser of this forum for now but glad I stumbled across this thread. I am enrolled into night school for 16 weeks next year to do a panel and paint course. Love to learn more about it etc.
    One question someone in here might be able to answer, with an oxy/acetylene set up, how much do the bottles cost to hire and/or refill etc? Ive heard all Oxygen tanks and acetylene tanks are not for sale and you must hire them. Is this true? I think ill get more use out of an oxy set up than a mig but will probably have both eventually.
  3. #33
    I think it works out about 200 a year for the acyletaline and a bit cheaper for the oxygen. I looked into it as well and whilst oxy is good to learn with, it can distort the panels allot due to the heat.
    Recently the place where I get my gas from started letting you buy outright bottles. So whilst it may seem allot of $ for a bottle up front if you use it on weekends and sporadically in the long run you save allot
    For shrinking panels I bought a map torch
  4. #34
    Nov 2015
    Michael
    Werribee
    Thanks Matt,
    I am a novice at best with both. I did do a pre-apprenticeship about 20 years ago and did welding for a month or so. Used to enjoy using the oxy more than the mig but yes, I used to blow holes in the metal with both haha...
  5. #35
    Mar 2013
    andrew
    perth
  1. Paint Preperation Tips n Tricks
    By Matt in forum Restoration / Body Work
    Last Post: 6th June 2013, 07:40 AM
  2. How to weld tips n Tricks
    Last Post: 21st May 2013, 12:46 AM
  3. Brake Installs – Tips, tricks and products
    Last Post: 16th November 2012, 03:54 PM
  4. Broken wheel nut (Need tips on removal)
    By GOT-20V in forum Technical - Rims & Tyres
    Last Post: 15th October 2011, 02:13 AM
  5. Rust removal
    By lawrencelalot in forum Adelaide & SA Events and Discussion
    Last Post: 16th July 2010, 09:01 PM
