Just posting in here so I can get to it quicker in the app.
Hey guys,
Come time for me to sell off the rest of my car stuff. Whats for sale?
Custom made Y pipe from turbos back to a 3" exhaust 3" cat and a 2.5" rear. Will seperate if you want just the Y pipes.
$600
1JZ manual ECU
$55 posted anywhere in aus
Torsen trutac LSD 4.1 gears, probably needs new bearings. The torsen is near new and has stuff all kms on it.
$sold pending payment
1JZGTE complete ready to run, was in my previous car and was strong in that. Dynoed 169kw atw on stock boost, this was before boost controller and exhaust. I havent driven it with either. Air con has been deleted and smaller belt installed, i kept the stock aircon bracket on there for support just removed the compressor. Hasnt been started in 12 months but i doubt it would give you grief as its been oiled. I compression checked it before i pulled it off the road and all clyinders were ~175 psi. Comes with complete loom, ecu, turbos and all access eg power steer
$sold pending payment/pickup
Bonvile engine mounts which puts the motor nice and far back giving more options for thermo fans etc.
W58 from late model JZA80, no noises crunches or oil leaks. I started to move the shifter forward but havent had a chance to finish it. Basically the extended bit that cups the shifter has been cut to be rewelded. I havent cut the shift rod that enters the box yet. I planned to not have to cut the trans tunnel to fit the position of the new shifter.
Bellhousing W series to JZ series
Custom made flywheel and semi-puck organic clutch (nice to drive but still grips). Clutch has approx 7k on it still grips like new.
Intercooler and piping for ma61
Aluminium radiator and fans
MA61 brake upgrade. 300zx/r32 skyline calipers, mounting spacers, discs (need machine), 1" master cylinder
Pics of it all
Pickup is form Currans Hill, Sydney. Can deliver for petty money. Any questions please ask 0413 938363
Thanks!
could be keen on the 1j, would you be willing to put it on a pallet and drop it at an e-go depot?
THE EVOROLLA
none of this SR shit . . . EVO 7 powered bitches
https://www.facebook.com/KeConversions
KE conversions - making your conversion simple
4AGE CA18 SR20 BEAMS 1UZ to KEXX mounting kits and hydraulic pedal box's available
all replied
Deposit taken on 1jz (and mounts), gearbox bellhousing and flywheel/clutch, radiator, intercooler setup and brake upgrade.
Sold pending full payment, all other parts still up for grabs
Prices dropped and updated stuff thats left
prices dropped
torsen sold pending payment. struts sold. Price drop
