hey all I am running a ae82 bigport engine with what I believe to be smallport 100kw map (not afm) electronics, and I have no idea of what leeds to order as it took me so long to track down the dizzy, its one the same as the picture
looks like a smallport dizzy
iv used those generic bosch leads with out valley cover, they are around $3-5 each depending on length.
(looks similar to this, just zip tie them someplace)
oem replacement kits cost a lot more
yer I hear that will give the generic ones a crack, I mean all it has to do is transport spark , seems the dizzy and ignighter do the rest. ive seen smallport ones running a really small leed like 5.0mm but the leads were way to small for this dizzy. worse case do you think ae82 ones might fit???
take the dizzy cap down to supercheap and do a test fit.
Don't big port ones have 2 wires and smallport 4 wires? Send jimmy1990 a pm, he can sort you out with well priced leads
Wow, thats my old engine bay form 6 years ago!
have used those generic leads on big port and small port.
but if u want the oem style leads better off going the oem style leads, I paid $80 for top gun back in 2008 LOL
yer I will get generic until I figure out exactly what the ome leads I need are + at least I will finally be able to start my car, only just done the conversion haven't herd her per yet
I had some topgun leads made to suit a ae85 4age, just need a longer one for the coil. These are only good if you're using the bigport valley cover though.
