Results 1 to 10 of 12
Thread: Ae86 4age conversion wont start!!
    Senior Member dan.91's Avatar
    Jul 2010
    Dan
    Taylors Lakes
    Default Ae86 4age conversion wont start!!
    Hey guys,
    Im in the process of converting my ADM AE86 to 4AGE, the motor is a standard bigport from an AE82. where I'm at at the moment is my car will crank and the fuel pump will prime but it will not spark to fire it.
    when you set the ignition to the "on" position the spark plug sparks once. obviously it should not spark at all unless you are cranking.. which is doesnt spark.
    My dad and I have checked the distributor, coil and ignitor and all are in spec for voltage, resistance etc. my motor has all correct earths and we have tried 3 different ECU's all to no avail. My dad used the 4AGE into ADM 86 wiring thread aswell yet still nothing. This car is making me crazy and I feel I am chasing my tail trying to fix this thing. So if anyone at all could give me some advice for extra things to check/tip,tricks that would be amazing. p.s I have checked all fuses etc and it is all ok.
    Veteran Skylar's Avatar
    Ken
    Do you have power at:
    The ECU memory wire (white?)
    ECU ignition power wires (black/red)
    The coil/ignitor power (black orange) (I'd think so if it's sparking)
    The injector power wire.
    Do the fuel injectors pulse when cranking?
    Has someone played with the distributor wiring? The colours should not match on either sides of the plug.
    Get an oscilloscope and check the output of the cas. A multimeter set to frequency function will also be able to tell you if there is an output or not.
    Start there.
    Jul 2010
    Dan
    Taylors Lakes
    We tried all of that and it has power at all of them, there is a red wire coming from the body that used to connect to the ballast resistor when the car was 4AC, do you know anything about that wire? also we tested for engine codes and it is putting out code 3, which is no ignition signal.
    Ken
    That red wire is a 12v start wire intended to give the coil a "full" 12v while cranking. Ignore it.
    If it's code 3 then you should have said that first. it's the cas in the distributor for sure or something related to it like the wiring. I take it you have STA hooked up for it to detect that it's cranking? Or are they smart enough to know that it's cranking by watching MAP signal?
    So then the relevant question is, has anyone touched the distributor wiring? Do you get a signal out of the CAS with an oscilloscope? Continuity between the ECU plug and distributor plug?
    Jul 2010
    Dan
    Taylors Lakes
    thanks for that,
    sorry that I forgot to mention the engine fault code in the first post, everything is connected such as the starter etc, I removed a distributor out of my friends AE86 that was running and fitted it into my car but I had the same problem as before. In your opinion does it sound like a wiring issue possibly?
    Elite rthy's Avatar
    Leo
    Tulla
    ignitor assembly?
    Veteran haveaparty's Avatar
    Mar 2010
    Brett
    Crestmead
    There should be a start signal wire (STA) coming out of the ecu that u will need to connect to the starter wire (thick black with white trace) the ecu should then recognize that the car is cranking over and fire spark and fuel. Also check ur spark plugs arnt fowled.
    Ken
    Code 3 is no NE signal so you can rule out ignitor and STA, for now. Car will start and run fine without STA anyway. Nice to have but not essential for starting and post start (via cold start injector)
    It's like you're not reading what I'm posting or something.
    Jul 2010
    Dan
    Taylors Lakes
    the wiring from the distributor to the ecu SHOULD be ok, as I pulled the entire motor out of a running AE82. so apart from fitting it to my 86 the wiring has not been fiddled with, only the 14 pin plug on the ecu has been suited to ae86
    Veteran slide86's Avatar
    Huw
    Hills
    Get a jump wire and put 12v directly onto the +ve of the coil and then see if it runs.
  1. ke70 4age conversion wont start
    Last Post: 28th September 2011, 09:24 PM
  2. 20v-16v conversion, engine wont start
    By meadan in forum Technical - Questions
    Last Post: 5th July 2011, 06:34 PM
  3. Smallport Conversion wont start
    By dogan in forum Technical - Questions
    Last Post: 7th June 2011, 11:45 PM
  4. Where to start??? need help with 4age conversion
    By Drift_Dan in forum Technical - Questions
    Last Post: 19th January 2010, 08:21 PM
  5. engine wont start
    By evil86 in forum Technical - Questions
    Last Post: 4th April 2009, 04:22 PM
