hi
first up
1987 mr2 aw11 auto (comes with manual conversion)
you're buying a project, everything pretty much there, just needs assembly.
comes with manual conversion (clutch, pedal box(fitted), clutch master(fitted), slave, all the linkages to the gear shifter etc)
the motor was running when i pulled it out but a few seals are leaking on it. bought a vrs kit that will come with the car (including crank seals)
will come with a spare 4age motor (7 rib with oil squirters)
also comes with spare rotors, pads, konni yellow shocks.
and have boxes full of spare mr2 shit. some other things i can't remember at this point.
want $1500 for it
second
is a ae82 corolla (twin cam)
has a running 20v in it with alternator problem and runs rough when it gets to operating temperature(havn't had time to find the problem( at this point i think it may be the air flow meter)). has kyb shocks and lowered springs. sloted rotors and an adjustable sway bar in the back. also has a small bit of damage on the drivers door/guard.
don't have photo's of it yet
want $1500
i am negotiable
can do a deal if you take everything.
located north of brisbane
0427 996 142
give me a call and you can ask me questions about it etc
