im pretty sure that you use the fuel setup that comes with the quad throttles (factory)
Hey guys I'm putting on itb's on my bigport 16v. Do I need to buy a new fuel rail system for the quads to work properly. If so does any1 know where I could buy them from ?
Thanks Dylan
So use the 20v fuel setup that comes with the quads?
you just use everything off your original engine, the 16V that is
Okay thanks guys muchly appreciated . Another question would the 20v injectors fit on fuel rail. If so would they be better than the stock 16v ?
no 20V fuel parts can be used
guess im wrong...sam knows best
20v like JZ engines have side feed injectors and therefore don't use a fuel rail at all, rather a cavity in the intake manifold that surrounds the middle part of the injectors
