15x7 0 offset with a 195/50 - fits fine, no dramas, sell those flipped things and look for something else
I swapped my old wheels for a set of meshies 15x6.5 with -27 offset but can also be +14 i like the deep dish look but when i tried to fit 195/50 tyres it wouldnt fit under stock guards, and then i tried 185/55 and still no luck, im new to this stuff so please help me out? will i be able to get these meshies on without guard if so what tyre and if i need to do guard work what should i do? and if its impossible for that size to fit can you please tell me whats the best size mesh for with deep dish that i could use even if i have to guard work
cheers josh
Well ive got 15x9 -10 offset on my car, with 195/50 tyres. did take a bit of work with the guards tho. Yours could fit if you really want them to, but not without guard mods
are the guards lips rolled?
im pretty sure there not and if they are its not much, are the front guards wider than the rear?
Front guards have a wider flare than the rear.
you will not fit -27s under the standard guards without a decent flare unless you plan on running -22 camber.
15x6.5 with -27, burn that shit,sounds like your new try 15x8 0 offset 195 55 15 with low till you learn more about wheels ie offset,sizes, what works on corollas, can start modding gaurds futher than just lipping
guards are lipped and rolled
and you are a retard for getting rid of the onis and equips
car has previously run 16x8-15 with a 205 40
Does it have a 3" lift kit installed??
