Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: BEAMS with Blacktop ITBs on standard ECU?
    Member Powerbite's Avatar
    Nov 2011
    Tasmania
    Launceston
    Question BEAMS with Blacktop ITBs on standard ECU?
    Basically iv found a heap of mixed info, so ill ask straight out
    So I understand you can run Blacktop ITBs on the BEAMS 3S-GE, but surely you couldnt run it without an aftermarket ECU? Im pretty sure the 3S-GE has an AFM where as the Blacktop doesnt?
    If its any help engine in question is an RS200 3S-GE
    Cheers, James
    Veteran Jdm-Mcc's Avatar
    Jake
    Wagga Wagga
    Correct, beams runs a AFM where as running B/T quads dont, however S/T quads do. Best bet is just run an adaptronic ecu with a loom to suit.
    Nov 2011
    Tasmania
    Launceston
    Yeah just as I though, basically id just prefer to run ITBs and trumpets on the 3S-GE with the standard computer but didnt think that was an going to be an option
    Jake
    Wagga Wagga
    With nissans you can run a piggy-back chip called a nistune to program the factory computer however im not sure if this sort of option is available for BEAMS?
    Veteran AJPS's Avatar
    Lonsdale
    you will need an ecu, which will give you cheap power anyway
    kaizen do an adaptronic plug n play loom to suit.
    May 2012
    ACT
    belconnen
    Just because it uses an afm doesn't stop you from running ITBs with a plenum...
    Didn't TRD make ITBs for the RS200 back when it was new? What ecu did it use then?
    Glenn
    North Ringwood
    they chose a motec to run the engine with the hi comp pistons and big cams etc
    Nov 2011
    Tasmania
    Launceston
    Bit of a bump, decided to go aftermarket ECU, what would you suggest? (BT quads w/ trumpets) also prices if you have them
    Power FC would be my ideal option but I don't think you can program the SXE/RS200 one to run a MAP?
    All info appreciate, cheers
    Veteran Skylar's Avatar
    Ken
    Pfc is a plug and play option. All of them will use all factory sensors. For nissans you can get l-(afm) and d-jetronic(map) models but you can't run map on an l-jet and vice versa. I don't know if the 3s has a d-jet option. You might be able it jerry-rig a gt4 pfc but we're getting far away from plug in ecu.
    You can get an adaptronic e420d for a little less than a grand, e440 select for a little over a grand. Halted sprint 500 at around a grand, ps1000 was like 1600 off memory, vipec v44 at ~1200 and v88 at 1800. There is also a lower level ecu at 1200 (link g4atom) which will also do the job sufficiently.
    You should be able to get the units a little cheaper if you look around as I'm quoting prices straight off a retail store.
    And after all that, go talk to your tuner and see what he wants. Probably the middle range as I don't remember if the haltec supported 4d tuning on the sprint, I'd think it does, I know the adaptronic and link/vipecs do. And you're probably best off using it. Hell, I've got a $500 megasquirt that I'm gonna have to tune myself because no one here probably tunes it. Real easy to figure out though.
  1. Blacktop Beams 3S-GE spares (MT ecu, ps pump, starter)
    By assassin10000 in forum Car Parts For Sale
    Last Post: 8th November 2011, 01:38 PM
  2. What ECU to run with ITBs?
    By McLEVIN in forum Technical - Questions
    Last Post: 4th February 2011, 09:10 AM
  3. 3sge beams blacktop extractors
    By 4A-G3 in forum Cars or Parts Wanted
    Last Post: 24th January 2011, 08:58 PM
  4. Blacktop ITBs Stacks/Trumpets
    By Eircamae86 in forum Cars or Parts Wanted
    Last Post: 26th March 2009, 04:38 PM
  5. Blacktop Itbs
    By damo46 in forum Technical - Questions
    Last Post: 16th May 2008, 04:01 PM
