I'm also open to offers for swaps for ae86/4age related parts so hit me up with your offerstext or call only please
Need the cash asap, all offers considered so don't be shy to ask
> S series diff housing with axles and hubs (good to use brackets or rebuild)- $300
> S series centres - 1 locked and one std needs good clean and new bearings $100 both
> rebuilt 4ac with blown head gasket $150
> 2 pairs of ae86 hatch tail lights - working but cracked, one not damaged $50 for the lot
> 4age smallport head immaculate condition with bigport cams $150
> standard 3 rib bottom end, stripped down with block, rods, pistons $50
> polished tvis plate $50
> early bigport crank (700 grams lighter than later ones)
> twin 45 mm webers setup (professionally rebuilt and never been used since) $1300 with bigport intake weber manifold $200 and has trumpets $200. The weber setup is worth an easy $1500 and I will only swap it for an efi setup, 4age, Sr, 3s whatever just as long as my hachi gets something running.
Call or text me, I can send pics too, prefer you don't message me on here as I can't access the internet most of the day. 0452194192 Ibrahim
S series Axles sold
I DO have a 7 rib block with the thicker rods (same as gze) crank and pistons with a bigport head I was going to use with the twin webers, I can throw that in with the webbers if you want to make an offer for cash or swaps. I was going to use this for a build but think I might go efi or turbo. Let me know what you have![]()
Need this stuff gone! I'll take the nearest offer on all the prices, don't be shy to ask !
Does the manifold come with the webers fur 1300?
DPB Automotive
I can probably do the webers with trumpets and manifold for $1400 or swaps for a rwd efi motor for my ae86, text me and we can sort something out champ![]()
still got the diff housing ?
Sold today* man sorry
all good im sure it went to a good home
