Results 1 to 4 of 4
Thread: WTB: N/A 4age timing belt tensioner
    Member smackdown.exe's Avatar
    Dec 2011
    J-D
    Gold Coast
    Aus
    Default WTB: N/A 4age timing belt tensioner
    Hey guys,
    Im about to run a 175mm 4agze pulley and ive been told i need a N/a 4a timing belt tensioner .
    If anyone happens to have a tensioner for sale please let me know
    im located on the gold coast.
    Cheers.
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    All 16v Timing belts use the same tensioner? I think you might mean fan belt tensioner.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    Jimmy is right, same part number right up to silvertop. It must be the multi-rib belt to compensate for the bigger diameter of crank pulley. You will need a longer belt too I would think.
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    I do believe what he is referring to is actually using a timing belt tensioner bearing in place of the original supercharger tensioner bearing.
    Because the 4AGZE one won't fit with the larger harmonic balancer.
  1. Replies: 11
    Last Post: 4th July 2013, 09:18 PM
  2. I have a rounded bolt - Timing belt tensioner - Any ideas?
    By maxhag in forum Technical - Questions
    Last Post: 11th April 2011, 08:18 PM
  3. WTB: 4age timing belt tensioner + gearbox sandwich plate
    By Pieman in forum Cars or Parts Wanted
    Last Post: 26th January 2010, 01:06 PM
  4. 4age rebuild parts - Oil and water pump, timing belt tensioner
    By trueno85 in forum Cars or Parts Wanted
    Last Post: 13th November 2009, 09:24 PM
  5. WTB: 4age lower timing belt covers
    By FATFIL in forum Cars or Parts Wanted
    Last Post: 28th May 2009, 07:46 PM
