When marks on the cams line up with tdc,crank should be at 0. Then pull out your dizzy and have dot on the shaft line up with dot on the housing (rotor pointing at number 1) then with engine running and te and te1 bridged set your dizzy to 10btdc.
hey all , cant get the 4age to run 16v redtop running smallport map gear, question is I set it to 10btdc, for the dizzy, so should I tweak the dizzy timing alittle , whats the go with the tps or is that for when its running, last one what was the fuel pressure set at again?
Also are you running smallport injectors?
yer all smallport electronics , injectors and ecu. thanks mate that makes more sense I tried to set crank to 10btdc then put the dizzy in so wonder she didn't want to fire
will try tomorrow arvo and let you know
still nothing , cranks over but no ignition, question is were to from here I deffinetly have fuel, dizzy and leads are all new, so what would people sujest next
you could have the timing 180 deg out, easiest way to check is to swap the leads around on the dizzy cap.
swap:
1 with 4
and 2 with 3
legend , went to fire and stalled then battery died lol but still a hope
lol!
I'm ashamed to admit it but i did the same thing once.
Does it have spark?
