if it's a ke70 then here is your answer
1. yes
2. yes, will need to change steering column to kesev item
3yes, just keep original t50 from t18 with your 4a bellhousing
4. they're a t50 so even if you change to ya kesev item it should be fine
As some of u may know i pooned thr wall at QR last week. want to reshell
thinking a t18 may be an option.
I am just interested in the parts compatibility.
1. Can i use my x-member from my ke?
2. Steering rack vs Steering box? can they be changed over if needed?
3. Tailshaft - Will the length be the same, using the same gearbox position
4. Gearbox tunnel size?
anything else that might be an issue
thanks
Last edited by bigm; 23rd June 2009 at 05:44 PM. Reason: computers in japan fail LOL
1. yes
What are/were you running in your KE?
2 - I don't think a rack conversion is quite that easy. Sure bolt in your crossmember and rack, but I think there is some work needed for a bearing in the firewall. I'm afraid I've never looked into it myself, but do some research before jumping in.
3 - Just keep an eye on the output shaft splines (Assuming you have a 4A+T50). Some T18 box splines match AE86 splines, others don't. Shouldn't be too much trouble though.
yeah output shafts on t-18 are differnet, just retain factory t-18 tailshaft and you won't have a problem
rack conversion is quiet easy. iv done it to mine
a man by the name of Chris aka C1 (the GOD of te72) has done this conversion, although i am not sure of his contact details.
pm me if you want em, he helped me with mine, tohugh egg 86 has also done it so yeah i'm sure he can help you out, though it's pretty much bolt in....
sorry for not fully explaining it
my KE 70 was running an SR and want to put that into the t18
but that sounds goood guys,
on another note, how does the hatch go for flex? it would be used for skids so what have people done to stiffen it up if need be?
thabjs
If it fits in a KE70 it fits in a T18. There are very few exceptions to this in the mechanicals department. A T18 is still an E7, shares exactly the same chassis as any AE71 or KE70.
Similar flex to a 86, Just use similar bracing to an 86. If you need to look at a rack conv you can take a peek at my crapper or pm me and ill send you my number, But as mentioned its quiet easy (but annoying if you get some wrong info)
