Page 53 of 56 FirstFirst ... 3 43 44 45 46 47 48 49 50 51 52 53 54 55 56 LastLast
Results 521 to 530 of 555
Thread: Slide Spec Ae71
  1. #521
    Veteran v-tec's Avatar
    Grant
    Gold Coast
    Only ever had two front lips, im pretty sure someone took off with one at a QR friday night when it fell off... Kind of a shame cause it had character. I got the good one on now.
    Fuel system is just a Vl pump and rubber lines... I should do a surge system some time but thats for later
  2. #522
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    you run rubber lines all the way from pump to engine or did you use original hard lines??
  3. #523
    Grant
    Gold Coast
    Yea just rubber lines, 8mm feed and 6mm return i think. Or it could all be the same size...
    The pump is external and just sits between the tank and the rear end and feeds up the the lines that are bolted into the fuel rail.
  4. #524
    Veteran trikzlane's Avatar
    Mereki
    Badassville
    you can use the original hard lines as thye flow perfectly, i do
    ~KEEP DRIFTING FUN~
  5. #525
    Davey & Riki-lee
    South Australia
    Seaford SA
    as do i with a turbo setup
    Our introduction - Click here
  6. #526
    Michael
    Crimebrook 2749
    i was a tard one day(ok more then normal) and removed all hardlines bar the main, so i had to run new rubber hose, finally found a good place to hide it the hole way along
    also, when you do track days you snap many axles???
  7. #527
    Mereki
    Badassville
    he has only snaped one axle so far, and thats when the gze was in, by memory, he got 3 years off a pair of axles, with na 4age
    ~KEEP DRIFTING FUN~
  8. #528
    Mereki
    Badassville
    imo, borg warners are alot stronger then s/t series
    ~KEEP DRIFTING FUN~
  9. #529
    Dave
    The Ghetto
    wow thats interesting ive never seen that been done before (rubber lines to engine) any chance of you getting some pics of ur fuel setup. Also dont u get surge problems? im assuming u fill over half a tank lol
  10. #530
    Michael
    Crimebrook 2749
    if you need some i can get some of mine too
    AWWWFUK YEA , ill defs keep the warner then
  1. Slide Spec Ae71
    By ke25 racer in forum KE70 / AE71 Owners Forums
    Last Post: 4th October 2008, 01:28 AM
