not sure if this helps but there are a couple of different rack clamps that take different thickness bushes. my early model ke bush was alot thinner than my 86 rack bush and from if i remember correctly my late ke rack bush.
Trying to find a reconditioned ke70 rack for my car, i have found a few places that do them but all the ones that are sent to me seem to be wrong. Ive had 5 sent to me now and they all use a much bigger D shaped bush than what my original has. The rack and x-member is defiantly out of a ke70 but all the suppliers tell me I'm wrong and my rack is not a ke70 rack. Whats going on did ke70 change racks at some point? I even have a set of super pro bushes that are listed as ke70 bushes that fit my original rack and x-member but not the new racks. Can anybody help me please?
Cheers Shea
ok ill have to get a larger clamp and see. i dont think it will fit it may hit the sump.
is the aluminium part that the bush wraps around the same size on all the racks you have?
Yeah all the reconed ones are but mine is smaller.
Do you have a model number available?
Toyo DIY is showing 2 different gear assemblies in the early model ke70. 79-81 has one type, 81-83 has the second type, which is the same as late medel ke70, 84 etc
No I dont have a model number. I got the rack and x-member from a wrecker the only info id be goin on is what u said earlier that the early model has the smaller bush which is the one that im after.
all fixed mate going to make it fit the most common rack.
thanks for your help
