Ep2.
Hey all,
New concept I am trying here just doing the entire build through video.
Hope it entertains you!
Ep1.
Ep2.
Ep3.
Thanks all! Any feedback is welcome, next big problem is sorting out the clutch...
Thats sweet. Got a pretty similar (shitbox) ae71 project going, gota love it when the 4ac starts. Good shit.
Great work guys, great to see good mates working together on a project. I do not know what your objective with the 86 is? (Track , roadie or other usage ). But noticed you found a bit of rust !!! There will be more ---- so strip the car back to basics , gut the interior, take all the panels , spoiler and drive train out. Blast the car inside band out with a pressure washer ( with drain plugs out ) , then go on the hunt for RUST with a screw driver and grinder. That way you will know where you stand before you have spent money on other things. Also a disassembly tip-----photo everything before tacking it apart and get some sandwich zip bags and a marker pen and mark all parts and catalogue all bolts etc ----- it will make reassembly much easier . Keep the videos coming!!!!
ONLY THE GOOD DIE YOUNG ------ I MUST BE VERY VERY VERY BAD
AE86 4AGE 16V N/A TRACK CAR ( RED )
AE86 ROLLING SHELL --- IN CASE i F-CK UP !!!!!! (PRIMER )
AE86 ADM UNDER CONSTRUCTION ( STREET CAR) 4AGE 16V , (RED )
AE86 Trueno ( RESTORE TO PERIOD GOODNESS ) White
AE86 4AGZE Wreck ( to be rebuilt into Khannacross fun car )
KE 15 x 2 -- SPRINTER ( RESTORE TO PERIOD GOODNESS ) RED
TE72 (T18) X 2 BIT OF PAINT , BIT OF MECHANICAL way we go RED
Soarer 1995 1JZ Factory 5speed (R154 )
Nice vids mate,just a tip to get over spray off your windows, use fine steel wool. Works a.treat
thanks for the helpful tips guys, will give them a go later!
Bit of a drama with the paint stripping !!!! When I use a paint stripper , I sand the area with say 20 grit (you are trying to grove the paint ) apply stripper , do not cover and be aware of toxic fumes . Leave on as per manufactures time scale . Then use a scrapper to get the bulk of the paint off. Then water blast or sand or do both. Fine sand , then clean and degrease the panel . Then seal it with etch primer . Then panel repair if needed, primer an paint .
Sounds easy !!! But take your time , do each step properly ( don't short cut ) and you will achieve a good result.
Thanks aircobra that's really useful info! Will give it a hot crack this weekend
I cant believe:
1- Someone has done that to ANY car......
2- You got the car running that well, it really sounds like you could just start driving it with no worries.
