not really sure what pads i should get, its going to be street car with a fair bit of track work. Drift not circuit
Hi mate,
Which specific pads were you after, or what are you using the car for?
Regards,
Greg
- GSL RallySport - Ph: 1300 884 836 -
Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
- QFM Performance Brake Pads -
Also specialising in
- DMS High Performance Shock Absorbers - Monit Rally Computers -
For a street car doing track work (as much as I'd love to sell you a pad 3 times the price) your best options will be the QFM A1RM. Equivalent pad to a Ferodo DS2500, but is relatively low dust and rotor wear, and a third the price of the Project Mu HC+ at $119 per axle set.
The Project Mu HC+ is an excellent entry level track pad, but unless you're prepared to change pads at the track, they're far too high in rotor wear and cost ($339) to be an ideal pad for street use as well. The A1RM on the other hand is quite a streetable pad (I personally run it in my Cross 6 ute that will never see the track), but I also use it on my rally car.
For front and rear A1RM you're looking at $238 delivered. Otherwise the equivalent Project Mu would be $339 for the front, and $289 for the rear, but I would strongly suggest only running them at the track.
price on drift pads in DB421 shipped to 6107. Also what are the prices on similar pads in diff brands that u do. cheers
Hi mate,
Project Mu Drift rear pads to suit DB421 are $165 for the axle set. There's not alot else available specific as a rear drift pad. The closest thing would be something like a QFM A1RM, and these are $119 for the axle set.
Regards,
Greg
Project Mu October Specials On Nissan Rotors!!!
For the month of October, we're having a special on Project Mu rotors to suit Nissan vehicles! If we run out of stock, you can order and pay for your parts in October and still receive the special prices. Delivery will be mid - November. All prices are per pair, full details on the rotors at
Hi mate,
D1 spec rear AE86 pads are $160 for the set. I'll have to check with them on Monday about availability because last time we wanted a set they were out of stock in Oz. Otherwise A1RM will do the job nearly as well, and is $119.
RDA7501S are $210 for the pair.
Regards,
Greg
Hi Greg...
Just wondering if you have QFM AR1 front pads and RDA slotted front rotors for JDM sprinter in stock? Also after set of either Project Mu D1 Spec handbrake pads if in stock. Otherwise will use the QFM AR1's in the rear too. Looking to purchase early next week.
Hi Ben,
Yep, got both front and rear A1RM and slotted rotors in stock for a JDM. We actually ordered for Cal (above) on Monday the D1 rears, and they were the last set in stock in the country. If you're desperate for them I can find out when they're getting more, but the A1RM's will be almost as good..
Regards,
Greg
