Results 1 to 10 of 17
Thread: Ae71 Suspension!
    Senior Member Flush-on-15s's Avatar
    May 2013
    dylan
    Echuca
    Red face Ae71 Suspension!
    Hey Lads!
    Just wanting to know a good low set up apart from cut springs and coilovers for a ae71 My mate just said get adjustable shocks and some king springs.. i dont want to be paying 2 grand for coilovers any ideas and set ups, what i might need to go with king springs? i have no clue.
    Have a Look at my ae71 streeter build thread!
    http://www.ae86drivingclub.com.au/fo...s-Clean-Spirit
    Quote Originally Posted by timbo View Post
    This is like reading the Women's Weekly.
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    I would look at buying a used set of coilovers, or talk to AJPS on here about some springs and shocks to suit standard struts. I would suggest upgrading to AE86 struts and brakes, as there's no decent shocks available for the ke70/ae71 struts also. King springs are too soft for any real driving.
    May 2013
    dylan
    Echuca
    Is the upgrade to ae86 struts and brakes a bolt off bolt on Modification? What would I need apart from the obvious AE86 struts and breaks? & how much would i be looking for a set of used Coilovers?
    Elite rthy's Avatar
    Leo
    Tulla
    what ur budget?
    best to do front suspension/brakes at the same time.
    May 2013
    dylan
    Echuca
    Well i dont even know how much any of this would cost but 1000 max really..
    Veteran johl's Avatar
    Johl
    to use front ae86 struts and brakes you will need ae86 steering arms. which is a good upgrade to get ae86 power steering arms for more lock.
    heres what i would buy-
    used coilovers up front with ae86 adm brakes. its not worth the money for the jdm brakes imo. the coilovers should have camber tops.
    ae86 used power steering arms
    suzuki sierra rear shocks or trd adjustable shocks if you can find some cheap enough
    ajps rear springs and possible adjustable platforms if you have the spare coin.
    xt130 control arms just to get a bit more track and camber.
    and last but not least a lock spacer.
    i have bought coilovers for around $300 so all up you should be able to do it for around $1000-1200
    Elite rthy's Avatar
    Leo
    Tulla
    I wouldn't even bother with adjustable coilovers, just use some decent springs and shocks should do the job with ae86 struts.
    inaddition to new superpro or similar bushings, swaybars, rca, panhardrod, etc..
    Maybe even xt130 with coilover sleeve kit, has a bigger disk and twin piston, not sure whats involved to get them in tho...
    May 2013
    dylan
    Echuca
    Cheers mate really helpful!
    +1 for ajps springs. Kyb aren't a bad cheap shock
    Alex
    Wagga Wagga
    Another plus one for AJPS springs and kyb shocks.
    Great value for money. Unless you are chasing lap records, kyb shocks are going to do the job for a corolla driver. Most people won't notice the difference between them and expensive variants. Just try and match the spring rate to suit the shock and you'll have a good setup.
    Alex's 4AGTE KE70
    Or so was thought...
  1. AE71 suspension questions
    By Sprinter Freak in forum Technical - Questions
    Last Post: 19th March 2011, 10:52 AM
  2. AE71 Suspension Upgrade
    By joey_jones1213 in forum Cars or Parts Wanted
    Last Post: 19th June 2010, 08:38 PM
  3. suspension parts for ae71
    By DOG the rolla hunter in forum Cars or Parts Wanted
    Last Post: 4th May 2010, 05:45 PM
  4. AE71 Suspension upgrade.
    By Drift_Donkey in forum Cars or Parts Wanted
    Last Post: 8th October 2009, 01:37 PM
  5. ae71 suspension noise!
    By Cerby86 in forum Technical - Questions
    Last Post: 14th April 2009, 11:04 PM
