What brand are the Rose jointed castor rods?
NEW PART ADDED!!!!
G'day guys and girls,
7AFE block with crank, conrods, pistons and timing belt $50
Bare smallport head $50
304 deg TRD 16v cam pair, 8mm lift $500 ono
Will post
288 deg unknown brand 16v cam pair, 8mm lift $250
Will post
KE70 rear venetians $50
Pair of smallport cam covers, text half removed $20
Will post
KE70 roof racks $50
Pair of rose jointed LCAs, good ball joints $250
Will post
Pair rose jointed castor rods $250
Will post
AE71 manual pedal box with pedals, brake booster, hydraulic clutch master, slave cylinder with lines $250
RA40 steering arm set-up for extra lock $100
Will post
KE70 35mm extended LCAs, good ball joints $80
Will post
AE86 engine cross member with manual steering rack and engine mounts for 4AGE $250
T50 speedo cable $50
Will post
FWD 4AGE lightweight pulleys $100
Will post
KE70 dash mat brown $80
Will post
Clear bubble dildo shifter 125mm $30
Will post
AE86 ADM front brake calipers with brake pads (no hubs) $100
all parts located in ingle farm SA and will only post items with WILL POST added
im not on here often enough to reliably contact so please txt or call me on nine nine.
will happily send photos to you but am having trouble uploading them on here.
thanks
Last edited by Shrek; 25th July 2013 at 10:15 AM. Reason: Sold items removed, new parts added
Originally posted by AJPS
"I would of given a thumbs up, but my face was in some super models breasts covered with coke"
Can you send me a pic of the KE70 Door window shades.
Thanks
Not sure what brand they are.
Rose jointed LCA's are buddy club
rose jointed castor rods are D-Max
PMd about rear springs
Hey man, I'll take the tachometer.
Does it come with the mounting bracket?
Big up's for the North East Massiv'
NSATB - New Skids Around The Block
Bump
would you seperate the exhaust from the extractors?
Hi mate would you consider posting the trd copy extractors and exhaust.i realise it is a bulky item and is hard to post.i live in Port Macquarie nsw 2444 and I have no problem paying the postage.thanks mate
