having heaps of lock isnt going to stop or help having under steer
what wheel alignment have you got???
S13 front end in corolla do mess up front end geometry
Hey, did a quick search on the forum and couldn't find anything.
I've been running s13 LCA's, knuckles, brakes and coilovers on my ke70 for a while now and its just too rough. I get under steer through turns even though I've got heaps of lock. I'm don't know too much about suspension set-ups, but I think the springs are too stiff because the rolla is alot lighter than a s13. I think the stiff springs also cause my understeer. Does anyone know what to do? Ive got 8kg springs at the front to swap for something lighter if that is the problem.
what tires are you running?...first point of call when you have an understeer problem...
8kg isnt too stiff in a corolla
Having installed s13 suspension clearly shows you have no idea about suspension...look at tyres and alignment followed by actual driving...then come back to us![]()
MY AE86 BUILD
dont be too harsh lazy....
without a lot more information, we cant help you.
this is all covered pretty well if you trawl enough through the pages of the s13 install thread in technical
06/07/2011
Delazy is right, I don't know much if if anything about suspension. Still have a few more questions though.
Why is s13 coilovers a bad idea for a ke70? Is it because of Matt's thread "S13 Suspension in an Ae86 - Bad for low impact crashes", or do they just not work well with a KE?
For an alignment are there specific specs I should be following?
And besides undsteer, why do I eat shit over every bump? Still Steppin says above that 8kg isnt too stiff. Is it something to do with the damper, or the geometry? and wouldn't softer springs help with understeer?
so many factors can lead to your understeering issues, what tires/wheels are you running? had an alignment? how much camber/castor/toe?
what brand of coilovers?
spring rates....some people like 8/6, personally i like 6/4.
Need More information as already stated.
S13 front end mucks with the Geometry in E7X / AE86.
How low is the car, what tyres / wheels, Alignment settings.
Also be interested to know if you have a Locked Diff and what tyres you are running on the rear?
While it seems hating S13 setups is the current "in" thing, I doubt it is what's causing your problem.
As mentioned above, check your alignment. Checks your tyres and tyre pressure. Check if anything's loose. 8kg springs are getting quite hard in my opinion, but again shouldn't cause major problems. If you have a locked diff then understeer on turn-in is normal and you just need to drive round it.
fucked shocks? lolz.
