Results 1 to 7 of 7
Thread: this really SUCKS need help mates
    Junior Member rocksteady racing's Avatar
    Jul 2013
    Tom
    Wisconsin
    Caledonia
    usa
    Default this really SUCKS need help mates
    Hello to my mates from the US, what sucks is too much vacuum, just rebuilt 16 valve TVIS motor from AW11 MR2, went with mild cams and bumped compression to 10.5:1, EGR pipe on exhaust manifold capped, this motor is creating so much vacuum it develops a loud squeak. charcoal canister is removed and line capped, pvc replaced with Moroso oil/air seperator between intake valve cover and intake plenum
    Jun 2011
    james
    oxford
    general area
    England
    Sounds like it could be an inlet manifold air leak.
    Post up a video of it and make sure you show the vacuum lines
    Veteran willa's Avatar
    Will
    Northern 'burbs
    When I started my turbo 4a for the first time, it had a squeak so loud you had to wear ear plugs. The cause was a leak between throttle body and inlet manifold.
    Will.
    SuperFunHappySliders
    SR's are ghey.
    Senior Member cooter's Avatar
    Sep 2010
    Craig
    Perth hills
    pretty sure your not suppose to plug the charcoal canister line either as its a breather for your fuel tank
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    Yea it biulds up mad pressure in your tank
    Small hole in fuel cap solves it(never had fuel piss out everywhere)
    Hair model Jacobxxx's Avatar
    Jacob
    Sunshine Coast
    i have hahah
  1. House mates wanted..
    By --Redwork-- in forum Brisbane & QLD Events and Discussion
    Last Post: 24th July 2010, 06:18 PM
  2. One of my mates Died last night
    By VeRm69 in forum General Topics (No Technical Questions)
    Last Post: 29th November 2007, 01:44 AM
  3. hatch is loose sucks in exhuast fumes
    By Charged86 in forum Technical - Questions
    Last Post: 17th November 2007, 11:08 PM
  4. your opinion on deposits to mates
    By Mattysshop in forum Offtopic Discussions
    Last Post: 30th January 2007, 07:15 PM
