FOR SALE SR20DET KE70
$6500
LOCATED GISBORNE SOUTH
Engine bay is a low km redtop sr20det motor is in superb condition
comes with td05-20g kinagawa brand new turbo on it. still internall gate
i recomend external gate kinugawa never got the internal gate to work perfect.
brand new 700cc injectors
rb25 afm
nistune tunned by dr drift.
I recomend fittinflg a z32 afm on it so u can cank boost up make it make some more power and feel good
currently 206rwkw on 17psi afm almost maxxed this is safest as is
600mm wide front mount intercooler
full 3 inch exhaust
engine bay has been cleaned up all unessary things removed
removable rad support
bay painted
wiring loom is a full custom job for engine
loom was built by plms devolpments.
dirveline
amazing condition sr20det box no noises or crunches
sunbury brake and clutch half organic half puck clutch 1200kg pressure plate so will never slip.
brand new tailshaft just made up as i used to run rb25 box
r31 28spline diff with 4.11 final drive and welded
brakes/supention
front is full s13 front suspention
brand new hsd front coilovers
modified knuckles
thick rack ends
new tie rod ends
driftworks offset rack spacers
lca removed lock stop
lock in the car is awsomee
i used a s13 k frame in the car
and has full functioning power steering
castor rods are cut and shut with new bushes
front brakes are new rotors and pads jus sr20det s13 brakes
whiteline front 27mm swaybar
rear has ajps 6kg springs with ajustable spring hats
belstein shortened shocks
whitline ajustble panhard rod
18mm whiteline swaybar
brakes are r31 rotors new
duel caliper setup using vs calipers new pads
interior
geniun brinde brix 2.0 in red as drivers seat on a geniun ae86 bride rail
s14 passanger seat
hydro handbreak
autotecnica steering wheel and boss kit
autometer boost and oilpressure gauge
watertemp needs to be fitted but cbf
rear seats are still in
cage is no good for this years specs
has a optimum drycell battery under the dash this is allowed due to being drycell cost me bloody 300bucks has isolator switch in the dash for quick access to shut power down to the car in an emergency.
fuel system
all inboot has a little carter pmp filling up a 2 ltr surge tank then a bosh 044 external feeds the new 5/16fuel lines up to the front
exterior is been painted red its not to bad front gaurds are abit munched from running big castor
wheels will be standard sr20 stockies with shit tyres
its missing one bolt on flare can get it from topstage.
It Aint A Motor If It Aint A Rotor.!!!!!!!!!!!!!!!!!!
double post and no pics?
