Results 1 to 10 of 11
Thread: Steering column has play. What do?
    Sep 2011
    Joey
    Queensland
    North Brisbane
    Default Steering column has play. What do?
    Own a ae71, and the steering column has play. I'm talking more in and out movement from the drivers seat then side to side, it has new rack and tie rod ends, wheel bearings etc already.
    Is there some variety of bush somewhere? Uni joint screwed? It's certainly liveable, it's just a quality of life thing for when it gets rego.
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    Possibly the uni joint is worn on the end of the shaft, or something as silly as the bolts holding the column up not being tight enough and it's just moving down the slots? Or the main dash support being loose?
    Sep 2011
    Joey
    Queensland
    North Brisbane
    Mmm, I actually checked the bolts on the column, might be the main dash support though or more likely something is worn. That said I swear every bolt on the entire car was loose when I got it, so that may be it. Its in for a roadworthy atm so pending failure I will pull apart the dash and have a look lol.
    Play in the steering is something you'd want to sort out pretty quickly.
    Sep 2011
    Joey
    Queensland
    North Brisbane
    So its just this and reverse lights I need for rego (stoked, although theres no wiring for the lights near the switch? a pain but anyway).
    Mechanic took a look, apparently its a bush on the interior over the outside of the shaft? Also no longer stocked. Had a look at a few diagrams couldnt really figure it out. Anyone experienced this issue/ is there anything aftermarket available or should I just go pull one from the wreckers. I seem to remember reading about something the same deal as an issue for drifting s13s, and a cnc'd alloy part being a replacement
    Mar 2011
    Mt Dandenong
    If you can measure it and get some sizes I will most likely have a brass bush that will do the trick.
    Sep 2011
    Joey
    Queensland
    North Brisbane
    Thanks for that, I've further pondered it and will be going to the wreckers and seeing if theyl let me pull apart one of theirs tommorow. I'll let you know.
    Sep 2011
    Joey
    Queensland
    North Brisbane
    So I found a complete (toyota from the looks of it) ae86 service manual online, couldnt find a *e7* one.
    Now I'm just confused. Thrust stopper? Figure I'm just going to just have to pull it apart.
    Sep 2011
    Joey
    Queensland
    North Brisbane
    All sorted, just went to kelly wrecking and pulled a ke70 steering column. It was the (completly missing) thrust stopper which apparently is just what the bearing sits in, and is just a bit of plastic. Odd. If I ever do this again il take up an offer of brass bushes, because they seem like they would be much more effective. Kinda looks like its meant to fold in an accident though, along with the column itself.
    Anyway, it looked like this. No wonder I had play.
    West
    The thrust stopper is adjustable to sort out the end float I thought, try adjusting that, I was able to tighten up a really sloppy column with it without changing any bearings on my ae71.
  1. Replies: 2
    Last Post: 3rd September 2012, 11:04 AM
  2. Replies: 1
    Last Post: 3rd July 2012, 05:33 PM
  3. ke70 steering column
    By egg_83 in forum Cars or Parts Wanted
    Last Post: 11th February 2009, 10:28 PM
  4. steering column
    By stej in forum Technical - Questions
    Last Post: 10th September 2008, 08:35 PM
Tags for this Thread
