Results 1 to 6 of 6
Thread: bigport tvis running smallport wiring and ecu
    Senior Member shammy's Avatar
    shamus
    vic
    albury/wodonga
    aus
    Default bigport tvis running smallport wiring and ecu
    hey all,
    got myself a bit of a pickell as said im running the smallport wiring and dizzy ecu injectors , but its all on the bigport 16v redtop, now my issue is I want to know if there is a way to have the tvis operating? or am I just going to have to suck it up and gut the plate??? as im having slight reving issue at lower rpm
    shamus
    vic
    albury/wodonga
    aus
    Or just an idea would 262 degree camshafts give me better power down low as well if I remove tvis plate ,
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    remove the plate man
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    What do you mean by a slight revving issue down low? Gutting the plate and fitting bigger cams isn't going to help with low end power.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    what you need is an RPM activated switch
    Pretty decent article on TVIS
    I'd remove it or look into a bigport ecu / loom if you can find it cheap enough but removing might be the simpliest option.
  1. Replies: 0
    Last Post: 5th May 2013, 11:36 AM
  2. Replies: 4
    Last Post: 2nd January 2011, 10:30 PM
  3. 4A-GE smallport ECU wiring
    By stahlz_ae86 in forum Technical - Questions
    Last Post: 17th May 2009, 08:05 PM
  4. Bigport ECU into Smallport loom
    By jy086 in forum Technical - Questions
    Last Post: 24th March 2009, 10:50 PM
  5. Smallport eng with bigport ecu?
    By Sparkle86 in forum Technical - Questions
    Last Post: 2nd July 2008, 02:35 PM
