no i would never attempt to to weld the port floor that would as you say warp the head beyond being useful. Devcon will be used to fill the port to the desired level. I've seen and read so many theories, discussions at work have even been a little heated as the head war heats up, lol. I want to go a little smaller than what the others are saying. I ultimately want to eventually boost the engine later on down the track so i know bigger wont effect that.
Standard manifold???? is definitely not up for the job on this head, my manifold needs to be as short as possible.
Engine will be dry sumped, TRD dry sump pan has already arrived. Standard length rods will be used to start with then i may change to longer rods later.
