Results 1 to 6 of 6
Thread: 4age missing
    Senior Member shammy's Avatar
    shamus
    vic
    albury/wodonga
    aus
    Default 4age missing
    hey all removed the tvis but still having reving issues, car gets to 2500rpm and kinda sounds like its missing or something tried to up load a video but not working atm. I can give it a gut full and it goes past , haven't got an exhaust on yet , ends at down pipe , wouldn't think it would affect it , engine : 16v bigport running smallport electronics, tvis cut out. not sure were to go next car idles fine under 1000rpm
    Veteran johl's Avatar
    Johl
    ecu may be in limp mode mate. try and get a diagnostic tool onto the ecu.
    there is some info on here from nikkojoe
    Elite rthy's Avatar
    Leo
    Tulla
    map sensor?
    shamus
    vic
    albury/wodonga
    aus
    will try the disconnecting map sensor tomorrow, thanx Mansfield read the article sounds like same issue, getting over all these little things just want it to work so I can drive it
    shamus
    vic
    albury/wodonga
    aus
    map sensor dissconneced car stalls, tried fuel , nothing will try led light tomorrow, what ecu wire do I connect it to again?
    shamus
    vic
    albury/wodonga
    aus
    FIXED!!!!, did the diagnostic got the all good no code, found leaking injector (busted o-ring), revs hard now
  1. fresh 4age on a microtech 02 sensor missing and running rich
    By JDMBenji in forum Technical - Questions
    Last Post: 17th March 2011, 09:46 PM
  2. What am I missing, 4age RWD into Aust delivered 4ac AE86
    By RacerMelb in forum Technical - Questions
    Last Post: 28th October 2010, 04:38 PM
  3. Jap 4age loom question, missing plugs?
    By deanoo in forum Technical - Questions
    Last Post: 11th March 2010, 10:13 AM
  4. what to do when missing bolts
    By evil86 in forum Technical - Questions
    Last Post: 24th February 2009, 07:16 AM
  5. What am i missing?
    By wide s13 in forum Technical - Questions
    Last Post: 27th December 2005, 11:39 PM
