Results 1 to 10 of 11
Thread: xt130 LCA & Adjustable Caster Rods.
    Senior Member Flush-on-15s's Avatar
    May 2013
    dylan
    Echuca
    Default xt130 LCA & Adjustable Caster Rods.
    Just a quick question.. I have been thinking If i change to xt130 corona LCA'S which are 10mm longer then KE70 LCA'S does that mean that my stock ae71 caster rods will be out? because wont the bolt hole's on the LCA'S be in a different place? so basically i would have to get a adjustable caster rod to compensate for the extra length? sorry if this is a stupid question..
    cheers. (:
    Have a Look at my ae71 streeter build thread!
    http://www.ae86drivingclub.com.au/fo...s-Clean-Spirit
    Quote Originally Posted by timbo View Post
    This is like reading the Women's Weekly.
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    just adjust the standard caster rods........
    May 2013
    dylan
    Echuca
    oh.. right?
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    The difference in length required for the castor rods will be negligable, as stated the standard ones will be fine. Only reason to go aftermarket castor rods would be if you wanted more castor than the standard rods allow, or to use rose joints instead of rubber/urethane bushes.
    May 2013
    dylan
    Echuca
    Ah! right thanks man (: i understand now haha. cheers.
    May 2013
    South Australia
    the standard swaybar links cause more trouble than the castor rods
    Senior Member pt_y2k's Avatar
    Paul
    Is the idea not to redrill the lca as to keep the sway bar link and castor rod mounted in the same position?
    Veteran AJPS's Avatar
    Lonsdale
    on 10mm longer arms, keep them as they are
    when you go 20mm plus then consider
    May 2013
    South Australia
    as above...
    until you hit +20mm and above, you can easily use the stock holes...i was using stock holes at +35mm, not good but do-able
    May 2013
    dylan
    Echuca
    Yeah i didn't want to redrill the LCA's and that? i dunno much.
  1. Replies: 6
    Last Post: 16th July 2013, 11:28 PM
  2. WTB xt130 lca's, ae86 struts & brakes
    By Flush-on-15s in forum Cars or Parts Wanted
    Last Post: 16th July 2013, 11:07 PM
  3. WTD: xt130 lca's/ new tie rods
    By john84ie in forum Cars or Parts Wanted
    Last Post: 7th July 2013, 11:47 PM
  4. Replies: 2
    Last Post: 15th February 2013, 03:15 AM
  5. Replies: 3
    Last Post: 21st February 2009, 07:14 PM
