Only worthwhile doing on N/A if you run higher compression really
is anybody running e85 on their 4age? I'm running my 180 on it now and it's given around 100hp extra, obviously there will be much smaller gains on a non turbo but interested to see how much of a difference it makes
As above...needs to be running 13:1 CR to see any solid power gains...it will however run cooler and cleaner...while being a prick of a thing to start...not worth the effort
MY AE86 BUILD
Exactly.... There is only so much advance a motor will take.
you can achive 100% VE with a force fed engine, but not even close with an NA.
E85 suppresses knock.. So more boost + greater advance timing
But NA you can only dial in more timing without increasing VE, to do that in an NA you increase compression ratio.
Sorry - VE is volumetric efficiency.
Interesting...So there is no benefit running an N/A engine on 105-108 octane fuel that burns cooler?
a stock NA engine.
considering the increased difficulty in getting it, the increased consumption and associated pumps and injectors, not to mention cold start its not worth the hassle,
on a high comp NA it is great from all reports and is the way of the -near- future
anyone ever considered the extra volume of the fuel in the cylinder, and the needs to overcome it?
I agree that in a stock motor the benefit of running E85 would be minimal and not worth the expense or effort.
When you lift the comp to around 11.5:1 a 4age is on about the limit of pump gas. You can only lift the comp so far before your forced to run a higher octane fuel like E85 or Elf etc. Running a fuel like E85 allows you to bump up the comp and timing to make more power so I would say yes it's worth while in race engines etc running high comp the fact it runs cooler is a bonus. It's also only around $3 a litre verses Elf at $8 for the same octane rating.
on the new 86's there have been a few tuners claim to get 5kw gains. Hardly worth the effort IMO
4agte or fa20T definately
