Results 1 to 6 of 6
Thread: Wade 872a Camshafts. Bigport 16valve running MAP.
    Aug 2011
    Greg.
    Default Wade 872a Camshafts. Bigport 16valve running MAP.
    Hi all, I have done some searches re running the wade 872a Camshafts ( 267 Degree Actual duration) in a JDM spec Bigport 16 valve with TVIS running a MAP sensor but cannot confirm if The wade 872a will run properly with the Std MAP Ecu. Do the 872a's have enough Vac to operate the TVIS system? I have found various posts with good results running these cams in Small ports and a AFM Ecu.
    Most agree that the 2202-RT093 HKS 256 8.0mm lift cams will work with a MAP Ecu and TVIS. Reading the HKS cam cards I have show the 256 cams actually have way more duration than "256". Example: inlet opens 20 BTDC and closes 69 ATDC. Thats 269 deg.
    The exhaust HKS 256 duration is even larger.Example: Exhast opens 62 BBDC and closes 38 ATDC. Thats 280 deg.
    From this info 256 is only a model/part number and has nothing to do with camshaft duration.256 is not even the duation at 1mm lift. (218 deg at 1mm).
    Let the constructive criticism flow....
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    I'm running Clive's slightly modified version with more duration of the Wade's grind in my bigport running map, a little trial and error playing with the cam gears and it loves it. Interestingly enough I'm getting better fuel economy at the moment too which is a bonus.
    Aug 2011
    Greg.
    Hi James,
    What are the specs? (opening /closing degree's) Part no etc? Does the TVIS still Work?
    Regards,Greg.
    Mar 2011
    Mt Dandenong
    I'll see if I can find the cam card and scan it in, TVIS still works fine. In my car fuel consumption has even slightly improved.
    Mt Macedon
    A friend once ran some 272 degree cams in his stock (I think MAP) bigport, just because he had them lying around. They worked and gave a performance improvement. I know no more than that though.
    Veteran timbo's Avatar
    Tim?
    Wild West
    I'm running TRD 272's in my smallport with stock JDM ecu. Pure awesomeness, idle is a bit rough and rubbish when cold but who cares. It has higher compression than normal and needs a little advancement with ignition timing.
  1. brand new worked 4age bigport head HKS/Wade/TRD
    By Mr Fujiwara in forum Car Parts For Sale
    Last Post: 2nd June 2011, 07:42 PM
  2. 4AGE 16v 277degree 8.6mm Wade Camshafts (QLD)
    By fandio in forum Car Parts For Sale
    Last Post: 12th March 2011, 11:47 PM
  3. 4AGTE Microtech Map Running a 4AG20V ST
    By 20vMK1 in forum Technical - Questions
    Last Post: 5th December 2010, 05:37 PM
  4. RWD intake manifold to suit bigport 16valve
    By mals86 in forum Cars or Parts Wanted
    Last Post: 1st February 2009, 04:16 PM
  5. Replies: 6
    Last Post: 22nd May 2007, 11:37 PM
