You will be fine to adjust the cam by hand (re spanner) to get it that little bit further.
Just make sure that you have the pulley on using the correct dowel hole (depending on intake or exhaust), as some 4ages have two ways the pulley will go on. Causing the timing to be correct, or way off.
