Results 11 to 20 of 23
Thread: cam pulley timing marks won't line up?
  1. #11
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    Timbo, no offense taken mate... there is two marks (as shown in the manual and which did line up prior to the rebuild) for examples sake we will say a mark on each at 12'oclock and intake has one at 3 and exhaust has one at 9, just find it weird/can't work out why they no longer match up exactly
    BENT MECHANIX - Garage 20:
  2. #12
    West
    When you tension the belt the inlet cam will roll over a bit and the marks will line up?
  3. #13
    Niz
    South~Slide Briz
    The belt is tensioned, (keep in mind I have had this engine running already) its the exhaust pulley which is slightly higher, so if the inlet pulley moved more it would be even more off, and assuming all that it wouldn't match up to the backing plate marks anymore...
    I guess its not really that big of a problem, just trying to figure out why it is like it is and if this will affect the way the motor behaves etc..
  4. #14
    Gunner
    Get some pics up so we can see what you mean, its very hard to determine if there is an issue, let alone what it is if we cant see it.
  5. #15
    Niz
    South~Slide Briz
    will over the weekend Rhys
  6. #16
    Niz
    South~Slide Briz
    just went to have look and see if I could get a pic, its hard to get a good shot to show what I mean..
  7. #17
    Get some liquid paper on it to help identify the markers...
  8. #18
    Niz
    South~Slide Briz
    nah I mean the angle (fwd) and shit in the way, rad hose/engine mount etc
  9. #19
    Gunner
    Take one looking down 45* at the cam gears. We wont need crank pic, if its at tdc.
  10. #20
    Jun 2011
    james
    oxford
    general area
    England
    Ok so I'm guessing the two horizontal marks were ones you made yourself as there are no marks in that plane on the standard pulleys ?
    Rebuilt the engine with shaved head and TRD thinner gasket ?
    The head now sits closer to the block (cam pulleys closer to crank pulley) so the belt cannot align the marks exactly, you probably wouldn't notice it on the standard timing marks
    but having marks opposite each other will show a difference.
  1. WTD: 4AGE 20v ST intake cam, cap plate, crankshaft timing pulley
    By sillycar_chick in forum Cars or Parts Wanted
    Last Post: 14th February 2013, 08:32 AM
  2. Setting timing without marks on crank pulley
    By geoff in forum Technical - Questions
    Last Post: 15th February 2012, 12:14 AM
  3. timing marks
    By HiLtOn in forum Technical - Questions
    Last Post: 16th February 2008, 05:03 PM
  4. 4k timing marks
    By HiLtOn in forum General Topics (No Technical Questions)
    Last Post: 16th February 2008, 12:08 PM
  5. Timing pulley off the crank?
    By FKN16v in forum Technical - Questions
    Last Post: 5th June 2007, 07:32 PM
