Hey ladies.
bought a 4 point bolt in half cage for my Ke70 from JDM Garage on the weekend but something cooler popped up that I want to buy so need to flog this thing off. Fits straight into Ke70/Ae86, was made in Japan and is mint. I since took the padding off because it was a bit filthy but underneath was a mint gloss black paint job with nearly no scratches! Has some surface rust on the base plate but other than that its mint, still has jap makers sticker which was hiding under the foam.
looking for $400 located in Toowoomba, QLD (hour and a bit from Brisbane). Will do cheaper if it is picked up or payed for before the weekend. Can provide pics of cage in my car (never bolted in, just test fitted)
YOU BUY MEOW!
Halfway through taking the foam off.
