Results 1 to 10 of 11
Thread: Differences between ke70 and ae71?
    Member johnny2's Avatar
    Jan 2013
    Josiah
    Tasmania
    northwest coast
    Default Differences between ke70 and ae71?
    This may seem like a dumb question but what are the differences between the ke70 and ae71
    Thanks
    Veteran johl's Avatar
    Johl
    Besides engines and what not the biggest thing would be hydraulic clutch in the ae71. It makes a 4a conversion that much easier starting with an ae71. It's not the hardest job in the world by any means so its not worth paying much more for an ae71
    Jan 2013
    Josiah
    Tasmania
    northwest coast
    To it the interia and exteria body work the same
    Jan 2013
    Josiah
    Tasmania
    northwest coast
    Look the same, I meant
    Veteran Konakid's Avatar
    Henry
    Eastern
    the first letter in the chassis code of toyotas denotes the Engine the car came with so with A or K means either A or K series engine.
    The E denotes thebody type, in this case corolla. The first number at the end determines which shape of that model with that engine, the second number incdicates an updated model in that same body style. KE70 was first then came the AE71, corolla went fwd with a new body shape after that so along came the AE82, AE85, then came another enw body shape called AE92, AE93 AE95 etc etc.
    AE71 has 1.6 litr 4AC engine, KE70 has 1.3 litre 4K-C engine
    AE71 has T50 5 speed Gearbox, KE70 Has K50 or K40 5 and 4 speeds gearboxes.
    AE71 only came in slanty front headlight model, KE70 came in both flat front model and slanty modern front.
    Interior trim is slightly different depending on models, as with exterior trim, colours.
    I should have just told you to go on wikipedia or search the forums in the search bar up the top ^^ but im bored.
    Jan 2013
    Josiah
    Tasmania
    northwest coast
    Thanks
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    Different radiator support so you cant use a ae71 rad(top rad outlet other side) in a ke(4age convo) although it looks like you can.
    Ae71 has side mirrors in the corners of the window, ke70 have 1 on drivers door
    The 1.6l vs 1.3 means a 4age into the ae71 technically doesn't require engineering
    Veteran AJPS's Avatar
    Lonsdale
    In a nut shell you can buy an ae71, drop in a 4age by swapping over the mounts and bolt the T50 straight up to it. Get some custom wiring and drive it.
    The 4age conversion bits (Hydraulic Peddle box , engine Xmember, tail shaft, Engine mounts and gearbox xmember , Clutch Slave etc. ) are easily $500 to purchase.
  1. KE70/AE71 glass differences
    Last Post: 8th December 2010, 01:28 PM
  2. T18 & AE71 gearbox differences?
    By Classic_King in forum Technical - Questions
    Last Post: 10th March 2010, 06:59 AM
  3. KE70 vs AE71 vs AE86 differences
    By QUINN in forum Technical - Questions
    Last Post: 1st November 2007, 12:51 AM
  4. differences between ae71, ke0, ae86 and t-18
    By adrianswood in forum Technical - Questions
    Last Post: 7th March 2007, 11:26 PM
  5. AE71/KE70 differences?????
    By h1_roll4 in forum General Topics (No Technical Questions)
    Last Post: 23rd April 2006, 04:10 PM
