Results 1 to 4 of 4
Thread: Sumitomo caliper rebuild - rt132 corona
    Aug 2012
    Alexander
    SEQ
    Default Sumitomo caliper rebuild - rt132 corona
    Hi all,
    Just picked up some front sumitomo calipers out of an 1981 rt132 corona, intending to use these in my xt130. Seals and pistons look as though they could use replacement..wondering if anyone has done a rebuild on any sumitomo calipers before? Tips and info appreciated. Cheers
    Veteran AJPS's Avatar
    Lonsdale
    javal will be here soon
    Jul 2010
    Rob
    Eastern suburbs of Melbourne
    I don't know what they look like as in do they have opposing pistons or just one single, if they have opposing cylinders i don't recommend splitting the housings as getting the seal between the calliper halves could be tricky & also there is the torque of the bolts which you would be hard pressed to get hold of, I just put a block of wood between the pistons or the piston & the side allowing say 5 - 10 mm of clearance & lightly apply air pressure through the brake line which will force out the piston to the wooden block, then remove the air supply & fit a thinner block of wood & repeat the process until the piston pops out, then clean inside the housing using Metho & tooth brush & then some 800 or so wet & dry, clean inside the back of the piston seal in the housing too & then dry & wipe out & then clean again with the metho. ( I don't recommend using anything stronger than Metho as it could linger after you have assembled it back together rotting / perishing the new seals ) .. Give the pistons a good clean on the outside using some 1000 or so wet & dry even a wire brush on a grinder can work just don't press to hard & keep an eye on things too & dry & inspect the Pistons for any pitting etc .. Fit the New piston seals in the housings Dry & install the piston dust seals dry too & then but a thin coat of rubber grease or brake fluid on the piston & then work it into the dust seal & make sure its dead square & slowly gently press it back into the housing, it should go back in without to much effort / force ..
    Aug 2012
    Alexander
    SEQ
    Thanks for your help, have been looking into this a little as of late. By the sounds of things perhaps something best left to the pro's.. going to look into getting a rebuild done by a brake shop or alternatively find something of same/similar in good cond.
  1. AE86 JDM Caliper Rebuild Kits
    By sc86 in forum SC Auto Parts
    Last Post: 13th November 2013, 03:48 AM
  2. (MELB) WTB: XT130 Corona front calipers ( sumitomo )
    By Wilson in forum Cars or Parts Wanted
    Last Post: 25th October 2010, 09:31 AM
  3. Parts for Rear JDM caliper rebuild!
    By haydenz in forum Technical - Questions
    Last Post: 25th August 2010, 12:57 AM
  4. JDM Rear Caliper rebuild kit
    By haydenz in forum Cars or Parts Wanted
    Last Post: 12th February 2010, 12:43 AM
  5. JDM caliper rebuild
    By robert nguyen in forum Technical - Questions
    Last Post: 5th June 2007, 09:16 PM
