So this stuff is not needed any more.
Razorback ECU with hand controller, link cable, full loom, relays, daewoo coil packs and leads.
This was on my ae101 4agze converted to turbo. All connectors are labelled, it's about as plug and play as it gets with literally 2 wires that need soldering (constant 12v and ignition). All the rest are just plug in and turn the key. The loom hasn't been cut so there's a lot to work with.
This setup made 202hp at 12.5 psi with a t28, 550cc injectors and an xf throttle body. Obviously a tune would be required (which is done on the hand controller) unless you have exactly the same setup as me.
$350 for the lot
HDI dual stage boost controller
Comes with the loom, even the box and instructions. I used this in my car for a while but now I'm changing to an external gate with my desired boost rated spring so no need for a controller.
$100
Bee r rev limiter. Never installed this and now I'm getting an ecu that does hard and soft rev limiting.
$200
Located at Tweed Heads NSW (not the Gold Coast technically).
Ill post at buyers expense
Cheers, Jase
