Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Thread: Toyota 86 + Forced induction = BOOOOOOOOOOM!
    Default Toyota 86 + Forced induction = BOOOOOOOOOOM!
    The guys at NRG Automotive have released pictures of the Turbo charged GT86 that had 3500kms on the clock before it let go.
    The pictures tell allot of this build, but by the sounds of it the rod snapped sending the piston into the valves bending them and punching a hole in the block.
    The valves sitting up here..
    What is left of the piston
    Busted Rod
    Please show your appreciation for the pics and like the NRG facebook page
    Senior Member AIROCOBRA's Avatar
    Bob
    ACT
    Weston
    Here is the thing ---- maybe these engine are not designed to be boosted , well no as much as this one , whatever it was. Sort of looks like someone got something really wrong , that is one hell of a failure !!!!!!!!!!!!!!!!!
    ONLY THE GOOD DIE YOUNG ------ I MUST BE VERY VERY VERY BAD
    AE86 4AGE 16V N/A TRACK CAR ( RED )
    AE86 ROLLING SHELL --- IN CASE i F-CK UP !!!!!! (PRIMER )
    AE86 ADM UNDER CONSTRUCTION ( STREET CAR) 4AGE 16V , (RED )
    AE86 Trueno ( RESTORE TO PERIOD GOODNESS ) White
    AE86 4AGZE Wreck ( to be rebuilt into Khannacross fun car )
    KE 15 x 2 -- SPRINTER ( RESTORE TO PERIOD GOODNESS ) RED
    TE72 (T18) X 2 BIT OF PAINT , BIT OF MECHANICAL way we go RED
    Soarer 1995 1JZ Factory 5speed (R154 )
    Moderator Frak's Avatar
    Jamie
    Just on this, I have dynoed an 86 and was shocked at the mid range dip in the torque curve BUT whilst at manufacturers training on this engine, noticed that the oil pump has a variable pressure delivery and in the area where the torque is lower, the pressure from the pump is also quite low, about 25psi from memory and then as the rpm rises it increases to 60/70psi( the pressure was also higher below the torque dip as well), I showed the trainer the power/torque curve, overlaid it over the pump pressure delivery curve and then started wondering what will happen when torque is increased in this range and oil pressure is not, what will happen????? I imagine bearing problems! It will be interesting to see if up graded pumps come out that do not have the variable pressure delivery from aftermarket tuners, or if we see a run of modified 86'ers running bearings or throwing rods!
    Hachiroku since 1994
    Veteran Konakid's Avatar
    Henry
    Eastern
    Frak why would they run a variable pressure pump in the first place?
    With a big turbo the motor could come on boost hard right where the oil pressure is low.
    Jay
    What sort of boost was the engine seeing in this instance?
    Rust is a way of life
    Aug 2013
    brett
    Oz
    I think the above question will help us all here.
    BOOST?
    Who tuned it?
    With what?
    We have done many turbo and supercharged kits now and yes we are aware of faults and failures.
    Thankfully none by us.
    BUT yes there is a risk with ANY mod on ANY car
    I'd love to see the top of that piston, that would tell us much more about what was wrong with the tune if anything. But given compression ring was sitting in the sump when it was pulled of it is safe to assume some form of detonation was present.
    Find it interesting that "This is what failed causing the problem other end was still connected to the crank and big end bearings still servicable" quoted from their facebook page when referring to the snapped rod.
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    Possibly boost causing the rod to fail under compression perhaps? On another note, I'm very interested as to why they would run a variable pressure oil pump? A small fuel economy benefit perhaps from less drag?
    Pretty certain I've seen the oil pump problem mentioned elsewhere that Frak touched on...I do also recall seeing a "modified" oil pump for them in my interwebz trawling...
    Jamie
    This was my first thought.
  1. Toyota 86 Forced Induction issues... Turbo Charging vs Supercharging My GT86
    By pizzaeater in forum GT86 / BRZ Technical Questions / Modifications
    Last Post: 3rd November 2014, 03:44 PM
  2. MRT review Toyota 86 vs Scion FRS vs Toyota 86
    Last Post: 2nd December 2012, 08:19 PM
  3. CROWER 4AGE Forced induction cam specs
    By kerola in forum Technical - Questions
    Last Post: 15th September 2010, 10:51 AM
  4. What head is best for forced induction (supercharger)
    By PRIMRK in forum Technical - Questions
    Last Post: 15th July 2010, 11:12 PM
