Results 11 to 20 of 25
Thread: Rear Main Seal - cause of failure shortly after install?
    Jul 2010
    Rob
    Eastern suburbs of Melbourne
    Engine Oil pressure wont push out the seal as the crankshaft rear main bearing journal & the rear seal are not on the same plain, but crankcase pressure from blow by etc Will push out the seal ..
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    i do rear mains everyday. i use assembly lube on the outside of the seal to get it in easier. i use excessive o-ring and seal lube on the inside of the seal.
    most common causes of failure is not enough lube on the inside or putting the seal exactly where the previous seal was. usually you get a worn mark on the crank from the last seal. push the seal further in or not as far in to avoid the mark.
    that all said, the last 4a rear main i installed leaked like crazy. replaced the seal using the same method but didnt push the seal as far in. still leaked like crazy. couldnt be bothered to do it again and after a week it stopped leaking. i used toyota genuine seals.
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    Hmm interesting, this was an epic leak though, I have an oil trail that goes up and down my street twice, into my driveway and also faintly extends to the local caltex.....
    Don't think its an oil pressure issue as pump is a brand new genuine unit... Crank was polished so old seating from previous seal is prob not a huge concern, I will re install without lube and push it in a extra mil or 2 and see what happens
    BENT MECHANIX - Garage 20:
    Jul 2010
    Rob
    Don't re-use the seal that is leaking though .. Replace it
    Niz
    South~Slide Briz
    that's a given
    Veteran timbo's Avatar
    Tim?
    Wild West
    Bit of bad luck! Check that the metal face is smooth too.
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    never use lube on the outside, and if the car has a issue(blow by etcetc) ill glue the seal in with loctite
    last bigport i pulled out of my ke70, when i pulled the flywheel off the seal fell on the floor(huge amounts of blow by) know exactly when it came out too
    Niz
    South~Slide Briz
    Loctite ay, which one? would using a small amount of permatec grey on the outer edge be a bad idea? (only because I have it)
    Gunner
    there is a specific one for it from memory, perm grey will do the job
    Michael
    Crimebrook 2749
    basically what ever we have had at work or at workshop
  1. rear main seal
    By sic86 in forum Cars or Parts Wanted
    Last Post: 13th October 2009, 01:17 AM
  2. how to take out rear main oil seal retainer
    By driftster in forum Technical - Questions
    Last Post: 2nd July 2007, 02:48 AM
  3. 4age rear main oil seal
    Last Post: 27th June 2007, 02:34 PM
  4. ae101 rear main seal
    By Blown86 in forum Technical - Questions
    Last Post: 29th August 2005, 08:53 PM
