Results 1 to 7 of 7
Thread: 4AGE surge tank/fuel setup for ke20 conversion
    Jan 2013
    Paul
    Default 4AGE surge tank/fuel setup for ke20 conversion
    Hey all
    I am converting my Ke20 to a 4age, it will have a stock 4age 16v Bigport in it.
    I am wanting to setup my surge tank, I already have a Bosch 070 fuel pump but wanted to know what lift pump i should get?
    Also would a 600ml surge tank and standard ke20 fuel lines be big enough?
    Paul
    Jan 2013
    Paul
    Any ideas?
    These are awesome
    Mt Macedon
    600ml tank is fine (I've used one on a 4AGZE for years). For a lift pump pretty much anything will do. A self priming, low pressure pump is good, for example a Pierburg, but at $150 there are cheaper options.
    Unsure about KE20 line size, but the stock Sprinter 6mm lines work fine up to at least 150rwkw and probably much more.
    Jan 2013
    Paul
    I've heard carter fuel pumps are good can anyone recommend any models/types?
    Senior Member CRONIK's Avatar
    Jul 2010
    Jaden
    P city
    Facet pumps are pretty good but just make sure the pump will be in a good spot to pick enough fuel up from the tank. I had one placed too high from the tank and wouldnt pump enough fuel into the the surge so ended up modifying my ke70 tank pickup for a EFI intank pump. (quiet easy and inexpensive)
    Eddie
    Is there a reason why people just don't run a single pump like a Weldon one? It removes the need for multiple fuel pumps and if the pickup is configured properly, there is no need for a surge tank either. Yes they are expensive but add up the cost of 2 pumps + surge and its basically already paid for.
  1. Replies: 2
    Last Post: 10th October 2011, 10:12 PM
  2. [WA] 4AGE 20V Adj Cam pulleys and Fuel surge tank
    By bui_ke70 in forum Car Parts For Sale
    Last Post: 9th April 2011, 07:27 PM
  3. Surge Tank Setup 4age KE70 Need Simplified
    By ke70 xx in forum Technical - Questions
    Last Post: 15th June 2009, 08:12 PM
  4. 4AGE Fuel/Surge tank Setups
    By Gullie in forum Technical - Questions
    Last Post: 12th March 2008, 11:39 PM
  5. lots of parts - 4a-ge,navara,ke20,turbo,surge tank,fuel pump
    By stretch in forum Car Parts For Sale
    Last Post: 27th February 2008, 06:50 AM
