Results 1 to 6 of 6
Thread: toda 20V pistons
    Jul 2009
    Daniel
    Morisset
    Default toda 20V pistons
    Anyone know if toda's black top 20V pistons can be used with a Silvertop 20V head, i know the combustion chamber is different in the ST head design to be more closed in compared to the open one of the BT, yes i also know that toda sell different sets for the ST and the BT, but has anyone tried a ST head with toda BT pistons.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    you would have to check the clearance of the edges of the piston to the quench zone, however keeping in mind the compression ratio would be very high. If your planning on running E85 it might work well?
    Pending your usage, You'd be better off to buy a b/top head + quads.
    FWIW: I've used a silvertop head with blacktop pistons, it is an interference motor but you knew that already right?
    I'm not so sure about the Toda pistons
    Jul 2009
    Daniel
    Morisset
    yea i know the BT is an interference motor , the main reason for the question is ive spotted some toda BT pistons for a good price, but i have a ST and i dont want to fork out the cash if they wont work without to much modifications. it looks like the difference just from going off the pic's on the toda website the ST has a cut away side so the dome area is like this shape / \ where the BT ones the dome area is straight up and down along the sides of the piston.
    as you guys have said getting a BT head and throttles would be the best way to go but then that requires finding one.
    I know of a guy who has used 16v smallport pistons with a blacktop head.
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    it will work fine if your stressed use a 1mm gasket
    the dyno pull to 300rwkw
  1. Replies: 1
    Last Post: 6th May 2012, 07:41 PM
  2. Replies: 17
    Last Post: 4th April 2012, 04:12 PM
  3. TODA 4age pistons
    By motorculture in forum Technical - Questions
    Last Post: 31st October 2011, 10:55 AM
