Results 1 to 10 of 14
Thread: Ae86 gt-apex trueno kouki 1986
    Nov 2011
    jody
    Queensland
    gold coast
    Default Ae86 gt-apex trueno kouki 1986
    selling my ae86
    it drives great and handles unreal
    has mod plate for recaro drivers seat
    rebuilt bigport engine,272 cams,cam gears planed head 10.9:1 compression
    ported head,acl bearings,toyota rings.valves reground,decked block
    crank flywheel clutch balanced
    new 3 puk exedy clutch/machined flywheel
    4.3 lsd diff
    2'' exhaust with 2.5'' rear muffler
    full nolathane bushes in all suspension
    40mm front roll center spacers
    adjustable panhard rod
    trd blue rear shocks,unknown fronts
    TRD/AJPS springs adjustable camber tops
    alloy rad,silicon rad hoses,mushroom filter
    ive been trying to get it close to stock in the engine bay,exterior,interior
    NEW ROTA RKR wheels 15X8 0 offset,sit really good
    ,NEW FEDERAL RSR 195 tyres So much grip its not funny
    interior is close to stock,has a good sterio cd/usd
    had on a dyno 114hp at 6800rpm
    is registered now but sold unregistered
    Goldcoast
    $13,000 ono
    0407 966 576
    probably forgot some stuff just ask and ill help if i can
    Nov 2011
    jody
    Queensland
    gold coast
    and i couple of photos of the rail damage under the rear seat.panel shop said $150 to fix
    this is the only bad bit on the car,everything else is fine.
    Nov 2011
    jody
    Queensland
    gold coast
    Aug 2013
    Matty
    Very clean 86, Do you have any better photo's of the chassis rail damage? Only asking as I am interested and showed a friend of mine who is a panel beater the photo and he thinks that is more like a $3000 job and the whole rail would need to be replaced unless is was going to be used as a track car.
    Nov 2011
    jody
    Queensland
    gold coast
    i can get more photos tomorrow,its not that bad,i work with panel beaters.a bit of work with a spot weld slide hammer would get it good.but prob cant beat new parts if you can get them.
    Member Auscan16's Avatar
    Oct 2012
    ACT
    PM sent
    Nov 2011
    jody
    Queensland
    gold coast
    here is more pics as per request
    also has razor back ecu with hand controller and slotted vented dba discs
    new engine and g/box mounts
    rear springs are not captive when car is jacked up
    Oct 2011
    Jamie
    ACT
    Tuggers
    This end up selling?
    Sep 2013
    lui
    clarkson
    this still available ?
    Nov 2011
    jody
    Queensland
    gold coast
    yes still for sale,now running stock ecu and stock cams
  1. Patiences 1986 Trueno GT-Apex
    By patience in forum AE86 Owners Forums
    Last Post: 26th March 2008, 03:30 AM
