I think you would probably have to make your own, and to be totally honest there really isn't much point with a 2s.
Hi guys
Just wondering about my 2S-c motor and if there is a weber manifold that fits and if anyone knows where to get one? Either sidedraft or single,but prefer twin sidedraft..
Thanks
Todd
Yo
they don't make sidedraught manifolds however a 3tc downdraught adapter will fit with a slight file of the holes.
Chuck a 32/36dgav on, sidies would be a waste of money. Don't get me wrong, my 2s keeps up with/beats stock bigports however they are not the kind of engine to be spending big money on.
I might look into that. I'm not to keen to speed much on the motor and if I am going to, it would be a engine swap.. what would be the easiest engine conversion to do in a st141 wagon?
3S-GE would be fairly straight forward, and a far superior engine even if it's just a series 1.
Definitely 3s.
Mounts line up, use the sump and pickup from 2s, bellhousing pattern is the same. Cut and shut manifolds, move dizzy to front of engine and bam its in.
Rwd water outlets are pretty easy to do, there is a thread somewhere in tech about the conversion.
Thanks! ohk, seems easy enough..
what about a 4age?
